ford 1715 new loader does not work
   / ford 1715 new loader does not work #1
lane123
lenoir nc
ford 1715
i just installed a new stoll 350 h loader hooked hoses up by color loader wil only move when raising 3pt hitch does any one have any ideal whats wrong
   / ford 1715 new loader does not work #2
Whoever sold you that loader better be able to answer that question .
   / ford 1715 new loader does not work #3
I believe it is not connected correctly.
What you appear to be doing is when you activate the 3pt, you cause the fluid to back up into the oader valve.
If open center hyd system, the flow should be something like this.
Pump to loader IN port, PB out to the 3pt, FEL OUT to tank .
   / ford 1715 new loader does not work #4
Last line in above post should read
Pump to loader IN port, PB OUT to 3pt, then to tank.
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51243)
2024 AGT...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
