Eugene Stiefel
Bought a 1715 w/BH loader from a equipment broker in Louesiana about 5 months ago. Tractor is showing 1100 hours but was not running and very little history on it. After getting it home I have had to replace the housing for the hydraulic filter (broken), the thermostat housing (probably broken because of water collection in bellhousing), re-surface flywheel because of rust pitting, water pump, fuel shut-off valve, complete wiring harness, spindal bearings for front 4WD axel, front drive universal joint, and all belts and hoses. After getting it to running for a few minutes it poped out a freeze plug in the top of the head and flooded the crank case with antifreeze. Then after replacing the freeze plug and starting it back up (for about 15 min) I noticed it had a knock in the engine. I pulled the head off and saw some vertical scaring in the #3 cylinder and a tell-tell sign of a valve hitting the piston. Today I took the oil pan off and discovered that the #3 rod liner/bearing was completely gone. There is some gaulding of the crank and rod cap and lower part of the rod showing extream heat. I noticed that there is at least one water jacket near #3 almost completely stopped up with rust. I'm not sure if that had anything to do with the failure or not. It looks like the cylinder can be honed out and recovered but I'm not sure about the crank. That is my next step. I've got a lot of stuff to take off to get the crank out. At this point I'm wondering what the price would be for a short block from a salvage yard. I'm about to quit havine fun with this puppy. Any advice out there?
