Ford 1715 clutch replacement manual
   / Ford 1715 clutch replacement manual #1
billkater
Olney, Il. Home of the White Squirrel
New Holland 1715
I am needing to replace the clutch in my Ford 1715 tractor. I have the service manual supplement pictured, but am needing Manual #40132030. It is the 13, 15, and 1720 Repair Manual. Anyone have a copy or know where to find one?
SERIAL. UK30757
MODEL. AK412T
UNIT. 7C13B
ENGINE. JB43-49210
   / Ford 1715 clutch replacement manual #2
I have the I&T Shop Manual FO-46 that is a singel manual for all models 1120,1220,1320,1520,1720,1920 and 2120. The engine clutch section of the manual is about 3 pages long with some pictures. I can attach a copy of the 3 pages if you want.
That would be great. I was looking at manuals last night and that one kept coming up. Was wondering how much it would show me.
Thanks
   / Ford 1715 clutch replacement manual #4
Here you go.
  • FO46 Clutch Pages.pdf
   / Ford 1715 clutch replacement manual #7
Pretty generic on working on the clutch.
:thumbdown:
I have the full, 4" thick, manual at home (traveling right now) and will send the right pages when I get back, although you are probably already done with the job. If you have any hints or guidance I am about to replace my clutch in the next month or so.
Audo
   / Ford 1715 clutch replacement manual #9
Haven't even started. Not enough hours in the day
I assume the 1715 clutch replacement would be very similar to my 1920.
It is a very straightforward job.
I had never done one before, but my helper had.
Took us almost 10 hours, first time.
Import clutch failed after 2-1/2 hours.
8 hours 2nd time.
DO NOT BUY AN IMPORT CLUTCH!
Messick's...Messick's...Messick's ...ONLY !!!!
   / Ford 1715 clutch replacement manual #10
8 hours 2nd time.
Thanks for the hint on Messicks!!!! I will avoid the cheap "solution"...
2017 FORD TRANSIT T150 CARGO VAN (A52577)
2017 FORD TRANSIT...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
1999 24DTA pintle hitch trailer (A53472)
1999 24DTA pintle...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50324)
2017 Taylor-Dunn...
2019 INTERNATIONAL LT625 (A52472)
2019 INTERNATIONAL...
