Ford 1710 Steering
   / Ford 1710 Steering #1
dboacres
Bronze Member
Central Calif hills & Glide, Or
Ford 2110, 1920, 1710
I have a Ford 1710 and a 2110 compact. Need to replace steering wheel on 1710 and have extra 2110 steering wheel. Any one know if the 2110 wheel will fit right on the 1710? At my age it's a lot of work to find out it won't fit. Thanks. John.
   / Ford 1710 Steering #2
didja check yer parts manuals?
here are the numbers... 3 cyl machine.. no... 4 cyl machine.. maybee, unless the 2110 is manual steering..
RickB may have something to add... All I did was lookup numbers out of the parts section. Note.. the 1710 offset..has the same numbers listed as the regualr 1710.
1710 manual steering: SBA334300070 WHEEL ASSY Wheel Assy., L/Cab Includes: Ref. 30, Start Year: 01/01/1983
1710 power steering: SBA334300070 WHEEL ASSY Wheel Assy., L/Cab Includes: Ref. 61, Start Year: 01/01/1983
2110, manual steering 4 cyl: SBA334310120 WHEEL Wheel, Steering, Start Year: 01/01/1983
2110, power steering 4 cyl: SBA334300070 WHEEL ASSY Wheel, Steering Includes: Ref. 61, Start Year: 01/01/1983
2110, manual steering, 3 cyl: D6NN3600B STEERING WHEEL Steering Wheel Assy., 18" (460.0mm) Diameter, Start Year: 01/01/1965
2110, power steering, 3 cyl: D6NN3600B STEERING WHEEL Wheel Assy., Steering, 18" (460.0mm Dia.), Start Year: 01/01/1965
soundguy
Thanks. I don't have access to a parts number book. Both are power steering. 1710 is 1985 standard model, 2110 is 1983 4 cylinder. Looks like you info says they use the same wheel. Thanks again. John
   / Ford 1710 Steering #4
parts listing is available freely online from the new holland web site if you don't have a parts manual.. just hit the site and do a parts search, then input your model tractor, then you can pull up explode ddiagrams and parts list by system.
good luck with the steering wheel swap.
soundguy
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
2022 CATERPILLAR 306CR EXCAVATOR (A51242)
2022 CATERPILLAR...
2012 Ford F-250 Ext. Cab Service Truck (A50323)
2012 Ford F-250...
2018 FREIGHTLINER CASCADIA (A50854)
2018 FREIGHTLINER...
1996 Lincoln Town Car Sedan (A50324)
1996 Lincoln Town...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
