Ford 1710 owner
/ Ford 1710 owner #1
dlkuzara
Port Charlotte Florida
Ford 1710
I live in South West Florida between Sarasota and Fort Myers. I recently purchased a Ford 1710 tractor with blade and loader. The first thing I did was purchase the (genuine) Ford shop manual as well as the I&T shop manual for the 1710. I am looking forward to this forum as a good resource.
I was replacing all the fluids and ran across some interesting problems. I cannot find anything local. The hydraulic filter was a WIX 51736 but Fram-WIX cross reference jumps from 51735 to 51740. I did find some hydraulic filters online, WIX 51736 & Napa 1736. The engine oil filter was painted over, so I do not have a reference, but it looks identical to a Fram PH43. The internet search for the engine oil filter got E1NN6714BB as well as 86546613, 86546613CDS and 86546613DS NEW HOLLAND, Trac OF2504. I could use some help with part numbers and where to get parts.
The fuel filter is more difficult as it is a metal and paper element that fits inside of a sediment housing. It is 2.262" long, 1.32" in diameter and the entrance hole is .515 (13mm). Does anyone know what this filter is or where to get a replacement?
/ Ford 1710 owner #2
Welcome to TractorByNet!
I moved your thread to the Ford/New Holland Owning & Operating forum. :)
/ Ford 1710 owner #3
If you go to napaonline.com and select a new vehicle, they have Tractors/Agricultural type in their drop-down box.
The 1710 should be listed in the 1983-1986 years (looks like they have all of the filters).
Also, messicks.com has parts diagrams in their New Holland section where you can get all of the Ford/New Holland part numbers.
Then do a google search on the part numbers and you should get some hits.
If you have a local New Holland dealer they should have the filters too (and some replacement parts if they are still available).
Be sure to check Messick's for prices on parts to prevent sticker shock if you ever venture out to the New Holland dealer (ex $1,000 starters).
-Neil
/ Ford 1710 owner #4
I get all the filters for my 1710 at NAPA. Be aware there are two different sizes of hydraulic filters and I couldn't find a way to tell which one I had until I pulled the old one off.
/ Ford 1710 owner
I did some research and this is my filter cross reference for a Ford 1710 Tractor w / Diesel Engine. As far as I know it is accurate. I bought all the filters online except for the Fram PH43 which I got locally, since I determined it was an acceptable replacement for the engine oil filter (see specs at end of post).
Wix filters
Air Filter 46421
Fuel Filter 33264
Hydraulic 51736
Oil Filter 51521
Air filter
NEW HOLLAND 86512888
AF2840
WIX 46421 UPC Number: 765809464216
Fuel Filter
33264 WIX
SBA36072013
FF0559900
330116270 WHITE
FF932 HASTINGS
SN21585 HIFI/JURA FILTRATION
565604048790 ISEKI
F682 KRALINATOR
MM404879 MITSUBISHI
3264 NAPA
83922484 NEW HOLLAND
87300039 NEW HOLLAND
360720020 PERKINS
F55193 PUROLATOR
R2426P RYCO
25013389 GMC
3922484 FORD FINISCODE
PF7545 BALDWIN
95264 BIG A
1876440 BOLENS
86264 CARQUEST
1273082C1 CASE
87300040 CASE
MAMM404879 CUB CADET
P552378 DONALDSON
FF615 FILDA FILTER
SBA360700031 FORD
SBA360700060 FORD
SBA360720020 FORD
CG9271 Fram
Baldwin 330116270
Hydraulic filter
WIX 51736
Napa 1736
Baldwin BT8391
Fleetguard (Cummins Filtration) HF6513
DONALDSON P552472
Engine oil filter
51521
E1NN6714BB
86546613
86546613CDS
86546613DS
Trac OF2504
87300039 Ford
PH43 FRAM
Part Number: 51521
Style: Spin-On Lube Filter
Product Media: Paper
Height: 3.790
OD Top: 3.660
Threads: 16
Burst Pressure: 325
Flow Rate: 7-9 GPM
Micron 1: 21
Outside Diameter: 2.834
Inside Diameter: 2.462
Thickness: 0.200
Part Number: 51348
Height: 3.404
OD Top: 2.921
Threads: 16
Burst Pressure: 275
Flow Rate: 7-9 GPM
Beta Ratio 1: 2/20=21/37
Micron 1: 21
Outside Diameter: 2.734
Inside Diameter: 2.430
Thickness: 0.226
PH43 FRAM = 51068
Part Number: 51068
Height: 4.338
OD Top: 3.660
Threads: 16
Burst Pressure: 275
Flow Rate: 7-9 GPM
Beta Ratio 1: 2/20=10/26
Micron 1: 21
Gasket Description: Attached
/ Ford 1710 owner #6
As Tabasco Jack's states, just go down to NAPA. I get all my filters from them for my 1710. The Hydraulic, they had to order and it took a day or two but they had it.
BOBCAT HYD MULCHING HEAD (A64279)
BOBCAT HYD...
SMOKOROMA BAR-B-Q BOSS SMOKER/COOKER (A64281)
SMOKOROMA BAR-B-Q...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
2017 CATERPILLAR 980M WHEEL LOADER (A64279)
2017 CATERPILLAR...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
(2) UNUSED 12.4-24 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED 12.4-24...
