Ford 1710 hydraulics quit after going up steep hill. Coincidence????
   / Ford 1710 hydraulics quit after going up steep hill. Coincidence???? #1
parluskq
wise va
honda 5013
Did a full fluid and filter change 10 hours ago when I replaced the clutch. Today I was moving some dirt and decided to work my gravel driveway. Our driveway is pretty steep, I went to the top and turned around and about halfway down I noticed the rear lift was notworking, shortly after my steering went as well. I let the tractor sit and the lift will work when it isエ cold but it isエ very slow and will stop working after about 5-10 minutes the power steering will go shortly after. Fluid levels are good. Drained half of the fluid, it was a little dark but no debris. I thought maybe I got air in the system but this one should self bleed I am pretty sure. The steering also feels jerky but not as bad as the lift. What do you guys think?forgot to mention, I just rebuilt the lift cylinder 3 hours ago...Also as far as I can tell there isn稚 a pickup sump screen on the 1710.
   / Ford 1710 hydraulics quit after going up steep hill. Coincidence???? #2
It seems to me that there is air in the system.
I thought that too but i drained the oil and added it back and still the same symptoms. This ford should bleed itself. I get and adapter today to i can check pressures. I am going to head back down to the farm in a could of days and see if i can figure anything out.
   / Ford 1710 hydraulics quit after going up steep hill. Coincidence???? #4
Running the lift up and down a few times should be adequate to process any air out of the system.
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
New Wolverine72 In Skid Steer Brush Cutter (A53002)
New Wolverine72 In...
2020 Steiner 450 Slope Mower (A51573)
2020 Steiner 450...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
