Ford 1710 completely dead dash - any ideas?
   / Ford 1710 completely dead dash - any ideas? #1
candersen10
Phoenixville, PA
Cat 262c, NH TN75, JD 6430 premium, JD 5325, Kubota BX2200, Ford 1710HC, JD 333E, JD3720, Farmall 504, Farmall 404.
Hello,
I have a ford 1710hc and the machine was recently run in the rain. After pulling it into a shed, I shut it down, but may have left the ignition on. The next morning, our guys couldn't start the machine so tried to jump it. They said they had the polarity right. The dash then smoked though and is now completely dead although the battery has since been charged. The fuse box doesn't have anything blown though. Any idea what we should check?
   / Ford 1710 completely dead dash - any ideas? #2
Sounds like they thought they had the jumper cables on right. Sounds like you might have some bigger problems. Might be mechanic time.
2007 John Deere 1770NT CCS Planter (A50657)
2007 John Deere...
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
WHITE CI-7 DRAW WORKS POWERED BY TWIN (60 SERIES) DETROIT 14.0L ENGINES (A50854)
WHITE CI-7 DRAW...
