jsmith4806
- Joined
- Sep 14, 2010
- Messages
- 3
- Tractor
- none yet
Looking at a Ford 1700 with FEL, 4WD, 5 ft ford bush hog and 5 ft blade. Guy wants $4,000, which doesn't seem too bad. Hr meter broke, but he claims it probably has about 4000 hrs on it. Used for 20 years to mow 80 acres 3-4 times per year.
maintenance has been lacking; when I checked the oil, it was down a quart, the gear box on the hog was loose, and the hydraulic hoses are cracking. The FEL seems great (very little use), and hydraulics seems strong. Doesn't smoke when running, but hard to start, and idles rough for a minute or two after starting.
Transmission seems OK, works in all ranges, and the 4WD works as far as I can tell.
Need some advice about what else to check, if price is in line, etc. The tinwork is a little rough, and there is some rust here and there, but not too concerning. I plan to use for keeping weeds down on a property we own (about 5-6 acres of weeds), and for plowing driveway in winter, etc. Other than that, it'll essentially just be a big expensive wheel barrow to carry stuff around and haul firewood, etc.
Thanks for any help! Jim
