Ford 1700 tractor with 770 front end loader
   / Ford 1700 tractor with 770 front end loader #1
minifarm1
Semmes,Al.
Ford 1700
The valve that works my loader also runs the 3 point hitch. It's leaking hydraulic fluid and I can't read the brand or part number. Northern Tool has some valves but I'm not sure if any of them would work, does someone know?
   / Ford 1700 tractor with 770 front end loader #2
I don't think anyone would have a clue unless you supply more information. Such as make model etc.
   / Ford 1700 tractor with 770 front end loader #3
Might want to ask over in the New Holland (which also includes Ford) section (link). There is a lot of good 1700 info/help there. Pictures of your setup would be helpful as well.
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A55852)
2003 Pierce Tilt...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
Toro Workman HDX-D Utility Cart (A55787)
Toro Workman HDX-D...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
Leeboy 685 Grader (A47477)
Leeboy 685 Grader...
2011 Ford Mustang Coupe (A55758)
2011 Ford Mustang...
