Ford 1700 throw bearing noise
   / Ford 1700 throw bearing noise #1
Texas Blues
Manvel Texas
Massey 1655 Ford 1700 2cyl, Ford 1600 2cyl Massey 135 3cyl gas
My throw bearing is making noise when I press the clutch. Has anyone done a clutch job on the 1700? Ive done plenty of clutch jobs in cars and trucks being a mechanic for 20 plus years. Im not concerned with the ability to do it, just some input on what I might expect to run into when taking it apart. Thanks! Tex
   / Ford 1700 throw bearing noise #2
hey Tex,
I have not done tractor split on my 1700... come to thing of it I've never done any tractor split in my life:D:D saying that I have done several clutch changes on rear and front wheel drive cars. I think 1700 would be much easier job than doing on my Honda clutch. Double clutch should cost about $800 and single clutch kit about $280 and the clutch disk itself is about $80. The bearing are no more than $25. But before you take a dive take a rubber cover off the right side of the tranny and take a peek inside, that might give you some clues. I have looked at my 1700 to see how I can do it should I need it down the road and I find it not difficult , provided you have a flat concrete floor, jack stands, floor jack and you should be good to go. If I had to do it I'd put my carry all in the back, lower it and park it on the floor where everything is flat and pull the front to separate, I hate the back end to back flip:eek:
JC,
I think I've got plenty of clutch pad, hope my bearing will last that long.
Thanks JC, too bad there isnt a grease fitting for the bearing. Its been a little noisy for awhile and works fine. Im not in a real big hurry to do it, but I can see it coming in the future. Thanks, Tex
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
2019 JOHN DEERE 5090M LOT NUMBER 93 (A53084)
2019 JOHN DEERE...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2019 RAM 3500 (A52472)
2017 GRAND DESIGN RECREATIONAL MOMENTUM (A52472)
2017 GRAND DESIGN...
