ford 1700 rebuild
   / ford 1700 rebuild #1
chris0044
nevada tx
ford 641 workmaster, ford 1700 4x4 fel
i was wondering do i have to buy a used block cause mine broke the bottom of the skirt out on one side
   / ford 1700 rebuild #2
Is your block aluminum or cast??? I have seen some cast block that were welded and or brazed over the years. The trick is you got to be really good with a torch and/or a welder. I have seen guys weld cast with a stick welder and use nickel rod. I've seen guys weld it with a wire welder and use stainless wire. However, these guys were really good at what they did. I had a guy weld some busted cast on the knotters of a baler once and that worked. He was good, been welding 30+ years. I could not have ever done it. You might see if you can get a block from an ag salvage yard, or find the exact same tractor in running order. Then you could use the "broken" tractor for parts. That is a farm trick special in the midwest.
   / ford 1700 rebuild #3
The Ford 1700 was built by Shibaura (Japan) between 1979 and 1982.
It has a 2 cylinder diesel with cast iron block.
The best (most obvious) solution for the OP would be to find a used block.
   / ford 1700 rebuild #4
Do you have a photo?
   / ford 1700 rebuild
20180112_163136.jpg20180112_163207.jpg20180112_163340.jpg here are some picture
   / ford 1700 rebuild #7
Is the damage from a thrown rod?
If you have the piece and it is not broken up I would braze the piece back in and hone smooth.
I have brazed a kick peddle housing on a 1950 Harley that was completely broken from a chain break and backlash.
It was still on the bike 8 years later when I sold it!
Plus other successes with brazing.
   / ford 1700 rebuild
i think im going to just grind and smooth the broke part. it would cost a lot to have sleeves done, and i checked to see how fare the piston come down at full stroke and its not close to the combustion chamber.
   / ford 1700 rebuild
Will some great news got the tractor up and going now I need a steering wheel
2003 Pace American Trailer, VIN # 4FPW540373G068816 (A51572)
2003 Pace American...
2006 International 4300 Water Tanker Truck (A52384)
2006 International...
2006 JLG 2030ES 20ft Electric Scissor Lift (A51691)
2006 JLG 2030ES...
(4) 55 Gallon Drums of Mixed Laundry Detergent and Fabric Softener (A51573)
(4) 55 Gallon...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
CONTACT INFO (A53084)
