Ford 1700 Range Selector stuck
   / Ford 1700 Range Selector stuck #1
darkinark
Today while hauling brush the range selector got stuck and I can't budge it. It appears to be in the neutral position, but when I select a gear with the mainshift lever it drives as if it is in a higher gear. Any thoughts to help? Also, I need a service manual for this tractor, are there any floating around on the web for free? Thanks
   / Ford 1700 Range Selector stuck #2
The question was asked several times before. Look at the link below and you'll find your answer. Let me know what part of the manual you need and I'll email it to you.
JC,
http://www.tractorbynet.com/forums/...700-range-selector.html?highlight=detent+ball
JC,
Thanks JC, I will try that tomorrow. I could use the pages of the manual that show opening up the cover plate. By the schematic posted elsewhere I cannot tell how safe it is to pull it off without any parts moving or falling out of position. I appreciate your help.
   / Ford 1700 Range Selector stuck #4
Darkinark,
You do not need to take the cover plate to take detent spring ball and spring. I'll post the section you asked tomorrow.
JC,
   / Ford 1700 Range Selector stuck #5
Darkinark,
Attached you'll find info requested.
JC,
JC,
Thanks, it is raining here today, so I will wait to try this (hopefully tomorrow). I appreciate the files, they will help alot.
OK, I loosened the bolts, would not budge; took the bolts completely out, would not budge; pulled the springs out, then it moved smoothly into gear. JC, thanks for your help and for the files.
   / Ford 1700 Range Selector stuck #8
Sweet:) Did you check the SS ball for roundness? was it roughed up? in either case I'd change the ball and put it back with the same spring unless spring is damaged.
JC,
No, I didn't check the balls because I couldn't get them out. My son has a magnet that will reach them though and I will check them. Thanks again.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
GOODYEAR SET OF 420/85R30 NEW AG TIRES (A52748)
GOODYEAR SET OF...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
Metal Platform (A50774)
Metal Platform...
2015 Peterbilt 320 EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2001 MACK MR688S TANDEM AXLE ROLLOFF TRUCK (A52141)
2001 MACK MR688S...
