Ford 1700 Range Selector stuck
   / Ford 1700 Range Selector stuck #1
darkinark
Today while hauling brush the range selector got stuck and I can't budge it. It appears to be in the neutral position, but when I select a gear with the mainshift lever it drives as if it is in a higher gear. Any thoughts to help? Also, I need a service manual for this tractor, are there any floating around on the web for free? Thanks
   / Ford 1700 Range Selector stuck #2
Multiple postings can only cause confusion and disjointed response. I'm glad you found the cure in NH forum.
JC,
Sorry, I realized I posted this in the wrong area, so I posted in the other one. Could not figure out if there was a way to remove this one. New user, again, sorry.
   / Ford 1700 Range Selector stuck #4
We all have done it:):) no worries ! You can try by editing your previous post and delete but the thread including the title needs to be done by a Mod.
JC,:)
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
2016 TRAILSTAR 40FT DUMP TRAILER (A52576)
2016 TRAILSTAR...
2003 Pierce Tilt Cab Fire Truck (A51692)
2003 Pierce Tilt...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
2017 Nissan Sentra Sedan (A50324)
2017 Nissan Sentra...
