Ford 1700 possible clutch issue
   / Ford 1700 possible clutch issue #1
geozeitl
Bronze Member
Green bay wi
Ford 1700
Use tractor and starting to notice when going up a very slight upgrade or pushing snow tractor tires crawl to a stop in 2and3rd gear. I dont notice the engine working harder. This tractor was like a tank before. Would push alot of snow and not stop. Is the clutch going bad or slipping. Any way to adjust or test
   / Ford 1700 possible clutch issue #2
Could be rim slipping in tire. Have you checked the air pressure? This is fairly common.
   / Ford 1700 possible clutch issue #3
Do you have any free play in the clutch pedal ?
Didnt check tire pressure in tires yet, have about a quarter inch of free play on the clutch petal before it starts turning the shaft to the clutch
   / Ford 1700 possible clutch issue #5
It would seem to me that your clutch is toast!
   / Ford 1700 possible clutch issue #6
Should be about 3/4 to 1'' when you push the pedal down before it makes contact (gets harder to push) Any oil leaks around clutch housing ?
   / Ford 1700 possible clutch issue #7
A split is not quite as bad as you might think, but if you do it, be careful where you buy the Chinese parts.
Using Chinese parts....I did it TWICE!
No leaks anywhere l adjusted to about 1 inch, seems better than what it was before. Is that normal to have adjust that from time to time
   / Ford 1700 possible clutch issue #9
Yes but you can only adjust it so much as the clutch lining wears down you adjust it don't ride the clutch or it will wear out fast . Think of it like brakes on a car when the lining is gone you will have to replace the clutch
Thank you both for the advice. Sure is a nice place to come for info
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
TC710 FINISHING MOWER (A50459)
TC710 FINISHING...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52128)
2016 Kawasaki 70...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A50323)
1994 Mack CH613...
