Ford 1700 not charging
/ Ford 1700 not charging #1
reswhiz
CT
Ford 1700
Hi All!
First off, forgive my long-winded ramble. Just trying to give as much info as I can.
I went out to do my pre-snowstorm check on the Ford 1700, and discovered the battery was dead. It started immediately with a jump, but is not charging.
I also noticed the headlights wouldn’t work, and the charge/oil lights, and water temp gauge were out as well.
After checking all the fuses, I discovered there was no power to the fuse box.
Checking out the back of the ignition switch I had:
Terminal 30 (power in) Good with 12v
Terminal 50 to starter works as it should, as it turns over and starts fine
Terminal 17 to glow plugs works, but there is also a mystery black wire added to it that I have to figure out (although it looks factory, it is not on the wiring diagram). I know it is tied in series with the glow plug indicator, but there is a third wire I don’t know about.
Terminal 18 is tied into the other side of the glow plug indicator. I am perplexed by this, as although the coiled wire looks intact, no matter how long I hold the key on, it doesn’t glow. But it is definitely warming up the cylinders, and aiding in starting.
Lastly, the AC terminal (which powers the fuse box) shows no voltage when the key is in the on position.
I triple checked everything to validate my findings.
With that background info, now to my charging question. Would a lack of power to the fuse box interfere with the voltage regulator?
I ask this because, believe it or not, I had a similar issue with my Case 580k just two weeks ago. It would not charge. Turned out that the bulb in dash for the charging indicator was burned out, and that shut off the alternator! New bulb and it works fine.
So my plan is to buy one of those $20 after market ignition switch’s, followed by a $20 voltage regulator if that doesn’t fix it. The alternator is original to the 1983 machine, but I would rather keep it, then replace it with a $90 Chinese knock off.
Anyone have any insight/suggestions on my situation?
Thanks!
/ Ford 1700 not charging #2
When my Ford 1900 charging system quit I found the regulator was bad. Bought a Datsun Z regulator and put it in (they are now electronic instead of the buzzing type solenoids). Worked fine for years afterwards.
/ Ford 1700 not charging #3
I believe the glow plug coil to which your refer may be used as an indicator for heating but it drops the 12 volt tractor supply to about 10.5 for the glow plugs. They frequently glow dimly or not at all. The cheap ignition switches may not have the glow plug position. I replaced my tractor's original switch with a cheapie and had to add a separate glow plug switch from the auto parts store.
Just to close the loop on this, turns out that the AC terminal on the ignition switch was dead. Got a $20 aftermarket switch off Amazon, and it is GTG!
/ Ford 1700 not charging #5
might not be the problem but a mouse might have cut some of the wires in two. l have had to splice a few wires back together over the years
2022 John Deere R4023 (A60462)
2022 John Deere...
INSPECTION (A61166)
INSPECTION (A61166)
Atlas HA-ECGO 3pt 5' Box Blade (A60462)
Atlas HA-ECGO 3pt...
2014 VOLVO VNL (A60736)
2014 VOLVO VNL...
2019 JCB 457 (A60462)
UNKNOWN  500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
