Ford 1700 manual steering box rebuild kit
   / Ford 1700 manual steering box rebuild kit #1
tkrlyon1
Ford 1700 4wd manual steering, 770 front end loader
Does anyone know of any places that sells a steering gearbox rebuild kit and / or sells an already rebuilt gearbox? Also looking for left side shifter. Mine is worn where it goes onto the slides inside the transmission and sticks in gear occasionally.
I haven't had this tractor very long. Appears it might be tough to find some parts when they wear out.
   / Ford 1700 manual steering box rebuild kit #2
Have you tried West Kentucky Tractor Parts online?
   / Ford 1700 manual steering box rebuild kit #3
I'd look at the exploded parts diagram. Is that a single sector shaft box right? Pretty simple designs. If you are lucky it has a couple thrust bearings, a needle bearing or bushing near the top steering shaft, and bushings and seals for the sector shaft plus an oring for the sector cover . Not worked on that box specifically, but have done a few like it, including a Kubota Japanese sub compact, etc.
I actually found one. I bought the steering wheel, steering column, and gearbox brand new (never been installed on a tractor). After buying the assembly and doing some research, I think it's actually a assembly that fits a kubota tractor but it works ok for my Ford 1700.
   / Ford 1700 manual steering box rebuild kit #5
Glad you found one!
Thanks
The sector shaft had been broken. From the research I have done this is a common problem with these gearboxes and the shaft is pretty expensive. I am hoping this kubota gearbox is a better design and will last longer.
   / Ford 1700 manual steering box rebuild kit #7
Sector and worn style boxes are all pretty much variations on a theme, I wouldn't expect much different in that box than any other :)
I suppose I should be content with finding a gearbox that will work. Parts for my ford 1700 are becoming crazy expensive, but even worse than that, they are becoming obsolete and completely unavailable.
   / Ford 1700 manual steering box rebuild kit #9
A lot of the Japanese components are similar if you can just figure it out. No cross references to look up.
Glad you found one.
2019 CATERPILLAR D6 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2018 HINO 258 SERVICE TRUCK (A51243)
2018 HINO 258...
2012 BOBCAT E80 EXCAVATOR (A51242)
2012 BOBCAT E80...
UNUSED AGT NT18K EXCAVATOR (A51243)
UNUSED AGT NT18K...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
1 T Truck Dump Bed (A50515)
1 T Truck Dump Bed...
