Hooked_on_HP
When you say it is running wide open how many rpm's is it turning. Injection pumps are not simple to work on. It takes special tools to calibrate the pump properly. The service manual says the pump is not servicable.(for the average person). My thought is this. Now you have a tractor that runs but not properly.Spend a little money and have a profesional fix the pump and the tractor should last a long time. If you dont get the pump working as it should and it runs wild you will end up with a pile of scrap. Insted of shutting the fuel off to kill the motor remove the tube going from the air flter to the valve cover. If the engine runs wild put somthing over the air intake on the valve cover to shut off the air.
Bill
Bill
