Ford 1700 hydraulic question
   / Ford 1700 hydraulic question #1
tkrlyon1
I am seriously considering using a power beyond valve on my tractor so that the front end loader and the three-point can be used at the same time.
My loader is using the accessory port under the seat for its hydraulic power and return. In order to use the power beyond valve I need a hose to be used as a return to the reservoir.
Does anyone know of a plug or port on the reservoir that could accommodate a return hose?
I would rather not have one drilled if I don't have to.....
Thanks in advance
   / Ford 1700 hydraulic question #2
Thanks in advance
This is the port you can plumb up the return in to the diffy housing.
JC,
Thanks JC you seem to have all the answers.... I will give it a try next week
   / Ford 1700 hydraulic question #4
You are welcome, I have not used it for anything but just verified that the hole opens in to diffy housing. I might use it as a return for a log splitter when I get one.
Jc,
You are welcome, I have not used it for anything but just verified that the hole opens in to diffy housing. I might use it as a return for a log splitter when I get one. Jc,
JC I just checked and mine does not have that plug......
   / Ford 1700 hydraulic question #6
Well, Dang. Have you cleaned up all the dirt and grime well to look under? The only way you can have easy access to reservoir is removing the panel behind the transmission. That is an aluminum plate that can easily be drilled, tapped and some fitting put in with a return hose. I have not seen that but I don't see any reason a guy can't try that.
JC,
Mine is 4wd so the plate you suggested (rear of shifter) will not work because it has the lever to engage the 4wd
   / Ford 1700 hydraulic question #8
Can you post a picture. If the cover opens up to the oil reservoir then it can provide for a return path to hydraulic oil. some how you need to bring the oil back.
JC,
500BBL WHEELED FRAC TANK (A52472)
500BBL WHEELED...
2019 Ford F-450 Utility Truck, VIN # 1FT8W4DT8KEF27612 (A51572)
2019 Ford F-450...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
2024 JOHN DEERE 331P-TIER SKID STEER (A51246)
2024 JOHN DEERE...
2005 Caterpillar 430D 4x4 Extendahoe Backhoe Loader (A51691)
2005 Caterpillar...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
