Ford 1700 Hydraulic Pump
   / Ford 1700 Hydraulic Pump #1
rmakarewicz
Ford 1700
My hydraulic pump quit and I got the rebuild kit from NH. I put some witness marks so it goes together the same. Everything looks worn. I'm not sure how it goes back together as the plastic pieces on mine are worn. Also I didn't undo the nut as I'm not sure if I need more witness marks. Anyone have advice or pictures of their pump?
   / Ford 1700 Hydraulic Pump #2
Witness marks are not needed, and could be a problem on the impeller if they interfere with end gap. Do you have a manual with clearances and end gap dimensions? Main thing is to clean very good, look for scored worn areas, check clearances, measure diameters of shafts and bores.
The witness marks are on the outside. The only specs I have are in the picture I attached. Ill clean it up good and ho from there.
   / Ford 1700 Hydraulic Pump #4
If all that came in the "rebuild" kit are the plastic seals and rubber O-rings it looks more like a reseal kit,
if the issue was the pump being worn it would be gear to pocket wear.
I wish you luck with your project and hope it works for you.
Thanks for the replies. Im new to hydraulics so this is a learning experience.
   / Ford 1700 Hydraulic Pump #6
I have a maintenance book, will post photos later for clearances.
2003 Ford F-250 4x4 Pickup Truck, VIN # 1FTNW21P33EC85506 (A51572)
2003 Ford F-250...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2017 Claas Jaguar 860 Forage Harvester (A53472)
2017 Claas Jaguar...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
