Ford 1700 Has a Hydraulic block, Need help with creating a Rear Remote AUX port for Log Splitter
   / Ford 1700 Has a Hydraulic block, Need help with creating a Rear Remote AUX port for Log Splitter #1
crosspike77
Ford New Holland 1700
I have a 1980 Ford 1700 tractor. I just acquired a 3 Point Hitch Tractor Supply Log Splitter.
On my tractor if you are facing it from the back, on the right hand side under the seat, there is a small block with a hydraulic hose coming out the top and a lever on the front (like by the seat).
I am assuming the hose might attach to the splitter's in hose, but then I'm not sure what to do about the return hose. There are some ports/bolts on that block that may need a hydraulic fitting to connect the hose to, but I'm not sure if it's that simple or I need to do more.
I have a feeling this line is supposed to feed a front end loader valve. I was thinking of just teeing this port and running two lines there.
I had run a return line to the second port on top that the hose is covering there.
I tried to run a line off of the port near the hydraulic control valve under front of seat, but didn't seem to run the splitter correctly.
I have a photo of the block with the hose coming out the top.
2015 EAST MANUFACTURING ALUMINUM SPEAD AXLE STEPDECK TRAILER (A58214)
2015 EAST...
2020 DRAGON ESP...
John Deere 5525 (A60462)
John Deere 5525...
2018 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2018 CATERPILLAR...
John Deere 6110M (A60462)
John Deere 6110M...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
