Ford 1700 fuel injection pump question
   / Ford 1700 fuel injection pump question #1
DUKEWAYNE
KILLEN
FORD 1700
I have just recently purchased a 1979 Ford 1700 tractor with 1680 hours . It's in good condition but I want to service it before using it this summer for bush hogging etc.
My question for you guys is can the fuel injection pump be serviced ? If so how ? What kind of pump does it have ?
Thanks for the forum. I really enjoy all the good information. 20180402_085441[1].jpg20180402_085446[1].jpg20180402_085338[1].jpg
   / Ford 1700 fuel injection pump question #2
Yes it can be serviced.. It is a Zexel/Diesel Kiki Pes2 pump..
Have you EVER checked or added oil to the pump??
You see the 2- 10mm bolts on the side?? 1 on top of the other..[Phillips screw head].. DONT USE A SCREWDRIVER..
That is your drain & full screws.. you add engine oil at the top breather cap..
To get the pump overhauled it has to come off & your looking at the 500.-600.00 range.
   / Ford 1700 fuel injection pump question #3
Wow, looking at that picture i see the same problem that my fuel filter bleeder has. The aluminum housing after 38 years strips out the bolt threads and then you are forced with finding something that will work. In this case I see a flat blade screw jammed into the hole. A word from the wise. BE VERY CAREFUL because it will strip out like no tomorrow and leak like a sieve. And I believe that filter housing is in the $300 range (if even available).
Steve
I haven't checked it . I have been told that it can be serviced and I've been told that it gets it's lubrication from the crank case and all you have to do is change your engine oil .
You've told me way more than I knew . Thank you thepumpguysc .
What kind of oil should I use ?
Thanks .
Which one is the fuel filter bleeder ?
   / Ford 1700 fuel injection pump question #6
Whatever ENGINE OIL your putting in the motor..
   / Ford 1700 fuel injection pump question #7
Filter bleeder is the one with the flat blade screw in it.
And I use whatever engine oil I put into the motor in my Fuel Pump on the 1900 and on the Jinma 2420. Usually, there's too much oil in it (meaning some diesel is getting in there too)
Steve
Thanks stevem5215
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51248)
UNUSED FUTURE MINI...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
UNUSED FUTURE QUICK ATTACH MAST W/ 29" FORKS (A51248)
UNUSED FUTURE...
TRUCKING INFO (A50775)
