Ford 1700 electrical warning light issue
   / Ford 1700 electrical warning light issue #1
larrywc
lusby md
ford 1700
After 960 hours and over 30 years my super Ford 1700 tractor's electrical warning light has started a steady flashing, on and off. The batery is fine, fully charged, all connections sound and clean. I just replaced the voltage regulator with a new one, same thing. When I unplug the voltage regulator the flashing stops. Is it the alternator? I have a simple electrical tester, how can I tell?
   / Ford 1700 electrical warning light issue #2
Check for a loose belt driving the alternator.
Many auto parts stores can test alternators. Ask if they can check yours.
Check the voltage, output terminal of the alternator ad ground. It should be higher than battery voltage. 14-15 volt range.
   / Ford 1700 electrical warning light issue #3
Normal operation for electrical light is on or off. Manual doe not mention flashing. Get an electrical schematic and trace continuity and check grounds for the alternator and voltage regulator.
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
2010 Wilson Hopper Bottom Trailer (A50514)
2010 Wilson Hopper...
2003 Honda 4x4 ATV (A50324)
2003 Honda 4x4 ATV...
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
Caterpillar CB-34 (A50120)
Caterpillar CB-34...
