ford 1700 clutch linkage vibration
   / ford 1700 clutch linkage vibration #1
dddeli
lake city fl
ford 1700
i have a ford 1700 series 2 wd. my clutch linkage rod has started vibrating in and out from the engine/tranny block. it moves about 3/8 of an inch either way. it does weather th clucth is engaged or not. the only time it stops is if the pedal is pushed ever so slightly. im sure this is a problem with the clutch and just want to know if anyone has run across this problem. i'm wondering if i will be able to acces it throught the plate where the gear shifters come through or will i have to split the tractor to even diagnose the problem. if so i will replace the clutch while im in there. any info would be appreciated.
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
2 piece Bale Ring Feeder (A50515)
2 piece Bale Ring...
Land Honor Quick Attach Hitch Adapter (A50514)
Land Honor Quick...
Case SC Tractor (AS IS) (A50774)
Case SC Tractor...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2019 INTERNATIONAL...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
