Ford 1700 3 pt surges up and down.
   / Ford 1700 3 pt surges up and down. #1
rayikeo2
Platinum Member
My 3 pt started bleeding down with blade attached with engine off. When I start the engine and raise the blade it pulses up and bleeds down in a continous cycle. When I shut off the engine I hear a clicking noise from the relief valve area as the blade drops. What might cause this?
I found the problem, the piston seal was cracked. I bought a new one and have the tractor disassembled ready to install the new seal. Can anyone give me helpful hints to get the new seal into the piston grove? Also to reassemble is ther any tricks of the trade i should know?
   / Ford 1700 3 pt surges up and down. #3
Putting the the seal in the groove is a one time shot, can not try to reuses the same seal if it is not done right first time. The seal cross section is u shaped with with the outer lip facing the cylinder head. Take a notice of the old seal orientation, the lips should face the top of piston that is painted red. clean the piston and the groove as well as you can, lube the seal and the piston and center it and try to push it over the circumference of the piston, don't use any thing to pry the seal. it is a tight fit but hand pressure, good lube and bit of patience you can slide it in the groove with the right orientation , miss the orientation and you'll buy another seal. I have a lengthy thread about it, use the search engine and there is a ton of stuff about it.
JC,
http://www.tractorbynet.com/forums/new-holland-owning-operating/90819-my-f-1700-testing-my.html
http://www.tractorbynet.com/forums/...ting/128725-ford-1700-3-pt-lift-new-post.html
JC, Thanks, I got it into the grove of the piston. Now if I can get the piston into the tractor cylinder I will have it made. Ray
Got it back togather and it works. Thanks to all that responded, especially JC Jetro. Thank you again, Ray I.
   / Ford 1700 3 pt surges up and down. #6
Ray,
Glad it worked out. good job and happy tractoring:D
JC,
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2019 FREIGHTLINER CASCADIA (A52577)
2019 FREIGHTLINER...
WESSEX AT110 LOT NUMBER 170 (A53084)
WESSEX AT110 LOT...
2017 FREIGHTLINER M2 BOX TRUCK (A52141)
2017 FREIGHTLINER...
Ryobi Compound Miter Saw (A51573)
Ryobi Compound...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
