ford 1620 leaking hydrolic fluid from hydrostic unit
   / ford 1620 leaking hydrolic fluid from hydrostic unit #11
Yes that is what I meant, black means diesel motor oil which would be a rear main seal
   / ford 1620 leaking hydrolic fluid from hydrostic unit #12
I took it he was saying that black oil would be rear main engine seal, not tranny.
rScotty
Don't know Scotty. All I know is neither my lube oil nor my transmission / hydraulic oil never gets black. In fact, with the engine oil when I pull the dipstick I can always 'see through' it. Only diesel engines I know of that turns lube oil black are DDEC diesels because of the amount of blowby carbon they put back in the lube oil.
2010 Chevrolet Impala Sedan (A48082)
2010 Chevrolet...
2018 Caterpillar 416F2 4x4 Extendahoe Loader Backhoe (A50322)
2018 Caterpillar...
2015 Hooper T/A Trailer w/Mounted Foaming System (A50860)
2015 Hooper T/A...
8ft S/A Utility Trailer (A48082)
8ft S/A Utility...
(1) Push Blade and (1) Disk (A50860)
(1) Push Blade and...
2010 Keystone Cougar 5th Wheel T/A Travel Trailer (A48082)
2010 Keystone...
