Ford 1600
/ Ford 1600 #1
Ryan44
1978 Ford 1600
Tractor will run and idol but not rev up any suggestions
/ Ford 1600 #2
check to see if fuel filter is clean. Close the petcock, remove the hose from the filter housing, and get a container under the fuel hose. Then open the petcock and see if youg et a nice steady stream of fuel. If not you might have junk build up in the tank. Finally, loosen the fuel cap to see if it makes it rev higher. Fuel tank is atmospheric and need to vent out properly for good flow of fuel.
/ Ford 1600 #3
After going through the steps to ensure fuel flow throughout the system be sure to bleed the air according to instructions. Then be sure the air cleaner is clear and air has a clear path to the intake - no obstructions.
/ Ford 1600 #4
Make sure the throttle lever is actually moving on injector pump.
2008 TRITON TRAILER WACKER MGT2S GENERATOR (A65643)
2008 TRITON...
1995 MACK RD690S T/A DUMP TRUCK (A64277)
1995 MACK RD690S...
John Deere 660 Hay Rake (A66408)
John Deere 660 Hay...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
Case CX75C (A62177)
Case CX75C (A62177)
2022 EZ-GO ELITE...
