Ford 1600
/ Ford 1600 #1
airpaintdan
Chelsea Ok
Ford 1600
I recently purchased a Ford 1600 compact tractor. The engine runs good but accordingly to the previous owner the 3 point was slow, especially in colder months. I went to the local New Holland dealer and purchased the high dollar hydraulic fluid from them and then replaced all od the fluids in this tractor. I still have no 3 point working and according to the service manual there is a filter on the pick up tube, but I have been unable to locate said pick up tube or even how to access it if I did find it.....any ideas?????
/ Ford 1600 #2
have you looked at the exploded parts diagram for the intake screen?
/ Ford 1600
The exploded parts view show the screen on the intake tube in the sump & I have yet to find this intake tube or an access to the hydraulic sump to change/remove said screen...hence my problem.
/ Ford 1600 #4
have you looked at the diagram and see the 3 bolt flange and followd the external suction line?
/ Ford 1600
I have and if I am correct the top side of the pump is the suction side and where it attaches to the transmission topside I have opened the 3 bolt flange but was unable to pull it out as it has a 90 degree bend on it and it looks like it would require the removal of the fuel injector pump to pull it out. To wit I really did not want to do, if possible. That area of the bell housing does not have any other access than the flange I mentioned, so if the filter is there it must be small and flush with the suction side.
Any ideas would be very much appreciated.
Dan
/ Ford 1600 #6
that pipe makes a sloped 90 down, and has the small suction screen on the end of it.
/ Ford 1600
That's kind of what I thought, but do you have to remove the fuel injection pump to remove that line as it sure appears that way?
/ Ford 1600 #8
you should not have to.. but then I never had a 1600. I have worked on a 1700 and a 1500, and didn;t on the 1700.
/ Ford 1600
I finally found it and the screen was clean and not clogged. My concern now is with all of the sumps full I have found that the screen was only 1" submerged, is that enough?
/ Ford 1600 #10
I" doesn't sound correct, has the tube been shortened?
/ Ford 1600
No, its factory. My concern is I thought this tractor used a universal sump for the hydraulics, transmission, and rear end as there is only one fill point. That being the case, why would there be only one inch of fluid in the sump where the screen is located when the others are full? I have also noticed that there is what appears to be a flush rubber plug to the left of the steering column that might be where a dipstick/fill point once was........any ideas????
/ Ford 1600 #12
i'd have to see pics of that plug you speak of.
I'm not familiar with the sump arangement on the 1600, I've simply not owned one.
I know some ford and NH machines have rear and hyds common and tranny seperate, some are all common, and some are all separate.
2021 PermaGreen Ride-On Speader-Sprayer (A64194)
2021 PermaGreen...
1985 GREAT DANE 45' SLIDE AXLE FLATBED TRAILER (A59911)
1985 GREAT DANE...
New Idea 5409 Disc Mower (A66408)
New Idea 5409 Disc...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
2022 EZ-GO ELITE...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
