ford 1520 - no ignition power to solenoid
   / ford 1520 - no ignition power to solenoid #1
99k1500
Oklahoma
TC55da
Ok guys, I am new here, enjoying my TC55. But recently purchased a 1990 ford 1520 as a project to fix and sell.
The tractor has set outside for 4 years without being started.
I changed the oil and filter.
Drained all the fuel
replaced the fuel filter
put in new fuel.
Put in a known good battery (borrowed from my TC55)
turned the key - relays click in the on position, but nothing in crank position.
I tightened the Power wire at the solenoid - Nothing.
I got a length of wire and was able to supply 12+ to the crank wire of the solenoid, the starter operates fine.
With the key in the on position and the help of some ether. It fired right up!
I see the clutch safety switch has been bypassed and the wires are simply twisted together. Are there any other safety switches? I know I need to fix the safety switch but am hoping to only make one trip or one order for the parts I need.
Next on the list is to change flush the radiator and hydraulic fluid and filter.
   / ford 1520 - no ignition power to solenoid #2
put in new fuel.
i believe all gear shoft levers has one and the pto lever has one
1263 (A50490)
1263 (A50490)
2023 MECALAC AS600 WHEEL LOADER (A51242)
2023 MECALAC AS600...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
2014 Mack CXU 613 Semi (A50514)
2014 Mack CXU 613...
2023 CATERPILLAR 259D3 SKID STEER (A51242)
2023 CATERPILLAR...
UNUSED RAYTREE QUICK ATTACH VIBRATING BUCKET (A51244)
UNUSED RAYTREE...
