ford 1520 - no ignition power to solenoid
   / ford 1520 - no ignition power to solenoid #1
99k1500
Oklahoma
TC55da
Ok guys, I am new here, enjoying my TC55. But recently purchased a 1990 ford 1520 as a project to fix and sell.
The tractor has set outside for 4 years without being started.
I changed the oil and filter.
Drained all the fuel
replaced the fuel filter
put in new fuel.
Put in a known good battery (borrowed from my TC55)
turned the key - relays click in the on position, but nothing in crank position.
I tightened the Power wire at the solenoid - Nothing.
I got a length of wire and was able to supply 12+ to the crank wire of the solenoid, the starter operates fine.
With the key in the on position and the help of some ether. It fired right up!
I see the clutch safety switch has been bypassed and the wires are simply twisted together. Are there any other safety switches? I know I need to fix the safety switch but am hoping to only make one trip or one order for the parts I need.
Next on the list is to change flush the radiator and hydraulic fluid and filter.
   / ford 1520 - no ignition power to solenoid #2
put in new fuel.
i believe all gear shoft levers has one and the pto lever has one
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
2016 HINO 268 26FT BOX TRUCK (A51222)
2016 HINO 268 26FT...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A50854)
2013 XLR...
JOHN DEERE 850J LGP DOZER (A50854)
JOHN DEERE 850J...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
