FORD 1520 hydro tractor powers out after warm-up
   / FORD 1520 hydro tractor powers out after warm-up #1
Plamondon
Arizona
FORD 1520
Once warmed-up tractor powers out (any gear and/or throttle speed) - can't even go up to full throttle in neutral and will likewise power out, just lifting empty front bucket. If left just idling for some time, it may clear up temporarily but comes back. Kind of sounds like a fuel starvation problem but already replaced fuel filter. Is it possible that #9846407 hydraulic oil filter could be plugging up? New filter but was since parked under Palo Verde tree that was in full bloom with tiny yellow flower peddles and some may have blown into the hydro oil filler hole behind the seat when I had plug off?r is that far-fetched? BTW, if I just want to replace the hydro filter, do I need to first drain out about half of the oil?
   / FORD 1520 hydro tractor powers out after warm-up #2
Is the fuel line swelling up on the inside as the tractor warms up? Is there something in the fuel tank that is plugging off the fuel line?
   / FORD 1520 hydro tractor powers out after warm-up #3
Sounds like fuel starvation, check fuel flow all the way from out of the tank to into the injection pump.
2017 PETERBILT 587 TANDEM AXLE SLEEPER TRUCK (A51222)
2017 PETERBILT 587...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2012 MAXEY TRAILER MFG 100KW GENERATOR TRAILER (A50854)
2012 MAXEY TRAILER...
2005 KENWORTH T800 (A50854)
2005 KENWORTH T800...
2013 POLARIS RANGER 800 EFI UTV (A51243)
2013 POLARIS...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A49461)
2015 SkyJack SJ86T...
