Ford 1520 blowing Hydr Filter Seal
   / Ford 1520 blowing Hydr Filter Seal #1
mrbrettbaker
64 dynahoe
I've got a good friend with an 87? Ford 1520. 3 times in the last 2 weeks he has blown the gasket rubber out of the hydraulic filter, and the filter has been replaced twice. I'm a 30+ yr mechanic and I'm betting there is some kind of restriction or stuck bypass but I have not gotten a manual yet (ordered) and I haven't gotten up to his house yet to look. I am hoping this is something someone here has seen before and can save me alot of work? Any ideas would be appreciated.
Thanks
Brett
   / Ford 1520 blowing Hydr Filter Seal #2
Used to be a significant problem often traced to New Holland's never-ending shuffle of filter suppliers and part numbers. The current SBA340501030 hydrostatic filter has not suffered seal failures in my experience. The factory measure of charge pressure probably will not indicate a problem. Properly install the correct, current New Holand filter if your friend is currently using ANYTHING else.
   / Ford 1520 blowing Hydr Filter Seal #3
The filter is on the suction side. Shouldn't be much pressure. Check the case vent. I have seen " dirt dobber" wasps block it.
   / Ford 1520 blowing Hydr Filter Seal #4
These tractors have a suction filter and an HST pressurized filter. My bet is that the problem is the pressurized HST filter and the problem can be resolved by RickB's method. NH has had a rash of blown HST filter seals, especially in winter when charge pressures are initially highest until warmup.
Thanks for the info. This is a spinon Napa filter #7088, before that a wix 557088mounted on the side of the engine. I have not gotten up there to see it yet, but will replace with a New Holland Filter if we are talking about the same filter? Were is this vent?
You are right about the Twmp, we are in Albany NY and it is very cold now. I does fail after first starting up and has been good if he lets it warm up awhile.
So, what are you thinking?
   / Ford 1520 blowing Hydr Filter Seal #6
I know Yanmars better than Shibaura, but the breather on a Yanmar is under the seat high on the trans/diff. Some have caps and others just a pipe bent in a 180.
   / Ford 1520 blowing Hydr Filter Seal #7
Stick to the Yanmars. This isn't a vent issue, and we are not discussing the suction filter.
To the OP: don't panic until you blow an OEM filter seal. You can call Greenwich, Amsterdam, or my workplace @ 518-398-7107 for a NH filter.
Thanks Rick, but now it's really panic time! We put the new OEM filter on and blew the O-ring out of it twice.Can you steer me in the right direction for an order of testing or diagnosis? Any help would be greatly appreciated!
Is there a bypass or other valve beyond this filter that may be sticking. He order a manual weeks ago and it still hasnt arrived so I have no hydraulic schematic to work with.
   / Ford 1520 blowing Hydr Filter Seal #10
In your other thread (Still insist on duplicating?) you say that the OEM filter would not fit. Time to get your story straight. A Wix filter is not and never was an OEM filter on a 1520.
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
Ford 641 Workmaster (A50514)
Ford 641...
2014 VOLVO TRUCK VN SERIES (A50854)
2014 VOLVO TRUCK...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
DOG HOUSE/CONTAINMENT SLID (A50854)
DOG...
Heavy-Duty Round Bale Trailer - Tandem Axle, High-Capacity Hay Hauler (A51039)
Heavy-Duty Round...
