Ford 1520 alternator wiring
   / Ford 1520 alternator wiring #1
Chief0907
Lascassas, TN
Ford 1520, John Deere 2025R
My Ford 1520, 1989 vintage, had a catastrophic alternator problem solved with new belt, new alternator, other assorted bits and pieces. It appears that the alternator was original, and I have replaced it with an exact replacement part. The problem is that the plug on the back of the alternator has two wires going to it. The wires were held in a plastic module holding the two connectors. That plastic has disappeared leaving the two wires separated with no way to determine the orientation of their attachment. The connection point is shaped like a "T". Both wires are pale enough that I cannot give you any color code but one does have a dark tracer, the other does not have a tracer. I have been unable to access a wiring diagram that might help me. Can anyone tell me if the tracer wire goes to the top of the "T" or to the vertical portion? The one wiring diagram that shows a bit of this area also lists diodes and such that flipping a coin to determine which goes where isn't very attractive. Thank you in advance for your help.
   / Ford 1520 alternator wiring #2
When you have two wires you have a 50 - 50 chance either way but for some reason you will make the wrong choice eighty percent of the time.
2016 KLEEMAN MS192 MOBILE SCREEN (A51242)
2016 KLEEMAN MS192...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
Kubota RTV500 (A47384)
Loader with IH Brackets (A50515)
Loader with IH...
