Ford 1510 Won't start - any suggestions?
   / Ford 1510 Won't start - any suggestions? #11
Needs for starting:
450 psig compression or greater at the 200 rpm rated cranking speed....and you need a power source to produce 200 rpm cranking speed for a minute or so...takes 200-300 amperes
Correct pump timing
fuel and ability to mist it into the cylinders
air for compression
more like 275 to 400 psi..
   / Ford 1510 Won't start - any suggestions? #12
I can dig my Ford I and T manual back out and post the paragraph if necessary to clear this up.
   / Ford 1510 Won't start - any suggestions? #13
It is VERY unlikely that compression has suddenly dropped.
The OP might first check negative cable condition ,and clean ground (negative) to frame cable attachment point.
Next : Replace both negative and/or positive cables.
   / Ford 1510 Won't start - any suggestions? #14
a cracked head would do that, I hope that's not the problem, check everything else first.
   / Ford 1510 Won't start - any suggestions? #15
Wow this discussion went off track.
   / Ford 1510 Won't start - any suggestions? #17
Read post 1, (turns over couple of times then clicks). It is not a compression issue.
   / Ford 1510 Won't start - any suggestions? #18
fixes for that were covered. if it STILL don't start, then it could be a compression problem.. anyway, the engine has to crank fast enough to get enough compression!..
   / Ford 1510 Won't start - any suggestions? #19
Make sure you checknthe connections on the starter itself, make sure that there is not a bunch of corrosion on the connector, (and its not green looking), If your happy with that,mthen try using jumper cables off your truckmconnected to the battery. That will help deliver extra cranking amps, even with some bad and or corroded cables, and at least you'll have something to compare, to the process your going through now. You also, can take the plugs out, then crank the engine several revolutions, with no compression. This will also make it easier for the starter to turn the engine over several times, and you shouldnt have any problems. If you do.. then you need to start focusing onnyour starter or bendix.
   / Ford 1510 Won't start - any suggestions? #20
Take the "plugs out" of a diesel engine.?? I'd like to see that..lol
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2020 Caterpillar 299D3XE High Flow Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
