Ford 1510 Will not start cold - need block heater for 1 hour to start
   / Ford 1510 Will not start cold - need block heater for 1 hour to start #1
Shupiuliuma
Caledon, Ontario
Ford 1510
My Ford 1510 will not start cold even in summer. 1 hour on the block heater and everything seems normal. The battery and cranking power appear to be adequate after the block heater warm-up, but cranking is way too slow when the engine is cold. Any ideas?
Also I tried pull-starting the tractor, but the engine never turned. Can this tractor be pull-started without damaging anything?
   / Ford 1510 Will not start cold - need block heater for 1 hour to start #2
are the glow plugs working?
Yes, I think so. When I pre-heat them the indicator glows and starting is much easier than if I don't heat them up.
   / Ford 1510 Will not start cold - need block heater for 1 hour to start #4
What weight oil are you using? How good is the battery and the starter? Do you have big cables between the battery and the starter motor? These are the things I would check.
I can't answer all your questions yet, but the first thing I checked was to see if the oil had turned to sludge. Changing the oil is my first task. Since the starter cranks well once the engine block has been heated, I think the battery is "good enough", but I won't assume that. It is an "economy" battery and if it needs replacing I'll probably upgrade Yes, cables need to be checked.
By way of background, I bought the tractor from a neighbor when it had only 1000 hours on it. I have only added 70 hours in the last two years and it is stored in the barn. There were no problems starting for the first year.
And one more question: Can this tractor be pull-started?
   / Ford 1510 Will not start cold - need block heater for 1 hour to start #6
If this is s standard gear drive machine it can be pull started.
   / Ford 1510 Will not start cold - need block heater for 1 hour to start #7
How many CCA does that battery have? I just had to buy a battery for mine and I got one that has almost 900 CCA. You want lots of CCA for a diesel engine.
2007 Ford F-450 Ambulance (A55788)
2007 Ford F-450...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
1992 CATERPILLAR 14G MOTORGRADER (A52709)
1992 CATERPILLAR...
DOOSAN G25 GENERATOR (A58216)
DOOSAN G25...
LOT: Fuel Transfer Tank, Tool Box (NO PUMP) (A59076)
LOT: Fuel Transfer...
2003 Pierce 75ft Ladder Fire Rescue Truck (A55852)
2003 Pierce 75ft...
