FORD 1510 tractor stalls and won't start!
   / FORD 1510 tractor stalls and won't start! #11
HELP!!!!
~My Ford 1510 tractor will run for 10 minutes at full RPM and then it suddenly shuts down and cannot be started till next day.
We drained the tank, blew out the lines from the tank to injectors, replaced hose from tank to fuel pump, replaced fuel filter, injectors and bled the system.
Also, there is no switch in the seat-
This is truly driving me nuts and I need expert advice please!
Thanks so much everyone:)
Please run it with the fuel cap removed and see how long in low idle you can keep running your rig and report back. I would suggest that you run it stationary not to slush the fuel around and make a mess with the fuel cap removed.
JC,
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Rooster Weathervane (A55853)
Rooster...
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2023 54in Hooklift Dumpster 15 Cubic Yard (A56858)
2023 54in Hooklift...
