Ford 1510 starter brushes
/ Ford 1510 starter brushes #1
fordmanwisconsin
Looking for source for starter brushes for a ford 1510 compact tractor. Unable to locate at dealer who shows a part # but parts are not available.
/ Ford 1510 starter brushes #2
Lookfor a company that rebuilds starters. They will probably have what you need.
Bill
/ Ford 1510 starter brushes #3
ditto that.. look for a starter, generator, alternator / electric motor place.. they can usualy order off oem number.. or at least 'will fit', based on application.
soundguy
/ Ford 1510 starter brushes #4
The Ford 1520 was made by Shibaura in Japan between 1983 and 1986. It's a 3 cylinder Diesel, 3.03 by 3.15 inch bore and stroke or 70 by 80 mm. It's a 68.3 cubic inch or 1.1 liter engine. 22 horsepower. The starter is a Hitachi.
Here's a forum for Shibaura tractors Shibaura -- Other Tractor Brands Discussion Forum
Here's a web site for Shibaura tractors Shibaura Tractor - Shibaura Compact Tractors, Used Compact Tractors, Small Tractor Dealers
If you find out which model Shibaura the Ford 1520 is equal to you might be able to look up parts for the Shibaura instead.
/ Ford 1510 starter brushes #5
I found my paper catalog, post back with some numbers stamped on the starter and I'll see if I can find either Ford numbers, or Hitachi numbers.
/ Ford 1510 starter brushes #6
the original starter number is hitachi s114-381. have you taken the brushholder out. these starters unlike the american counterpart was built using a 3 brush set. it ran 2 '+' and 1 '-' brush holder. if you cannot find them call me on monday 800-303-3170 i can supply them. i get several call a week for these starters and can get remans also kinda pricey also keep in mind the negative brush is welded or silver soldered to brush plate which takes a lot more heat to work can supply ready to install brusholder in need to. just call
mitch becton
/ Ford 1510 starter brushes #7
update on repair parts for 1510 ford starter. i can supply the brush set the brush holder with '-' brush the drive/clutch and the solenoid. if needed call me at 800-303-3710.
thanks
mitch becton
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
2019 John Deere 460E Articulated Dump Truck (A60352)
2019 John Deere...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A61307)
2020 Takeuchi...
2024 AGT INDUSTRIAL  H13R (A60736)
2024 AGT...
Metal Cash Drawer (A59317)
Metal Cash Drawer...
22" PIN-ON EXCAVATOR BUCKET W/PINS (A60429)
22" PIN-ON...
