Jan 31, 2018 / Ford 1510 injection pump lubrication #1 N nate1616 New member Joined Jan 31, 2018 Messages 8 Location Milton, fl Tractor 1510 ford On a model 1510 ford tractor with a shibaura engine, how is oil circulated to the cam box to lubricate the injection pump, the lifters and rollers and the cam gear? Thank you for any help.
Feb 15, 2018 / Ford 1510 injection pump lubrication #2 9 90cummins Veteran Member Joined Mar 17, 2011 Messages 1,191 Location Florida Ma. Tractor Ford 1720 SSS 4x4 Turbo Charged The injection pump is built into the engine and is lubricated with engine oil thru pressure/splash. 90cummins
Sep 22, 2018 / Ford 1510 injection pump lubrication #3 jones6780 Gold Member Joined Nov 30, 2008 Messages 417 Location Lizella, Ga. Tractor Ford 1700 4wheel drive, Yazoo/Kees Max2 Zero Turn Not sure on a 1510, but my 1700 has a small separate reservoir in the pump, change with regular engine oil every 200 hrs. https://www.tractorbynet.com/forums/new-holland-owning-operating/144468-ford-1500-1700-injector-pump-6.html
