ford 1500
   / ford 1500 #1
hoot405
ford 1500
1981 20 hp shibaura 2 cylinder diesel. running fine when parked with new antifreeze. sat for three years, one winter got down to 0. went to start, checked oil and clean green antifreeze shot out. what? cracked block?
   / ford 1500 #2
that's one of those problems where you need to do at least a removal of the head, and if that's not cracked, or the head gasket is not leaking, the real problem needs to be found. don't run it like this, with antifreeze in the oil!.. a 50/50 mix of antifreeze and water, mixed before it is added to the engine, is needed for full freeze protection, maybe water got added afterwards?..
   / ford 1500
thinking water in oil with out turning engine over shouldn't be head or gasket, right? cracked block would let water in just sitting.
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2022 Caterpillar 420 4x4 Extendahoe Loader Backhoe (A49461)
2022 Caterpillar...
48ft Low Boy T/A Trailer (A49346)
48ft Low Boy T/A...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
1997 HUBBLER BROS. LOGGING TRAILER (A50854)
1997 HUBBLER BROS...
