Ford 1500 Tractor Ignition Tumbler (Novice Operator)
   / Ford 1500 Tractor Ignition Tumbler (Novice Operator) #1
allisons
Ford 1500 Tractor
Active duty military member settling down for retirement and I just purchased a 1983 Ford 1500 diesel tractor. It's in great shape, however, the key is cracked and bent. Looking for some tips on how I can easily remove the ignition tumbler.
Thanks in advance.
   / Ford 1500 Tractor Ignition Tumbler (Novice Operator) #2
To the best of my knowledge, on the order of a dozen Ford/New Holland tractors, they all use the same key. If your only problem is a mangled key head to the local NH dealer or Messicks Parts for Tractors & Equipment and get a new one. Heck Lowes , in some areas may have them. If you are bound and determined to replace the tumbler head to the NH dealer or Messicks and buy a new switch assembly. Just be prepared to pay careful attention to the wire orientation and order...there are a bunch of wires.
   / Ford 1500 Tractor Ignition Tumbler (Novice Operator) #3
:welcome:
To the TBN forum. Glad that you joined and this is the right place to get help with anything.
Thanks for your service. Where are you retiring to?
Richmon VA area.
Air Power!!!
   / Ford 1500 Tractor Ignition Tumbler (Novice Operator) #5
Almost neighbors then. I have 26 acres in Lanexa, round about Mile Marker 220 on I 64.
   / Ford 1500 Tractor Ignition Tumbler (Novice Operator) #6
I have a Ford 1100 that I have purchased 3 times, and it still uses the original key that it had with it when I first used it, back in the mid 80's. It has a small screwdriver, that stays in the thumb hole of the gas lid, ready to start the old girl up when needed. Same screwdriver has gone with the tractor and came back home every time it has left here.
David from jax
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
8x12 Custom Built Chicken Coop (A51573)
8x12 Custom Built...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
(4) 55 Gallon Drums of Bonderite (A51573)
(4) 55 Gallon...
2011 Toyota RAV4 4x4 SUV (A51694)
2011 Toyota RAV4...
