CliffordK
Veteran Member
- Joined
- Mar 8, 2013
- Messages
- 2,068
- Location
- Eugene, Oregon
- Tractor
- Toro D200, Ford 1715, International 884,
I have a Ford 1715 which may be similar.
There is a lockout mechanism on the clutch, and possibly the PTO. Anyway, check that the clutch sensor is properly connected if your tractor has one. I believe that it can be temporarly bypassed with a loop of wire from the in to out connections too.
You should be able to verify that it cranks over fine by touching the big terminal to the little terminal on the starter motor/selenoid using a screwdriver or something similar. Expect a little spark, of course, but the starter should start cranking over.
The big terminal on the starter, of course, should have power 100% of the time.
To bypass the ignition switch for the starter on a longterm basis, you can put a switch between the two terminals on the starter... You probably want to choose an intermittant on switch, rather than an on/off switch.
This wouldn't affect any other electronics which may be required for fuel & etc.
