Ford 1310 4x4
/ Ford 1310 4x4 #1
chrisn
Eatonville, WA
'49 8n, '52 8N, '61 Allis Chalmers D12 with FEL, '07 Montana R 4944 with FEL, Ford 1310 with FEL
Recently picked up a fairly well preserved 1310 4x4 with 770A FEL - 760 hours
To create a baseline I’ve been, greasing zerks, changing fluids, adjusting the clutch, trying to take slop out of the steering, getting the lights working etc.
Haven’t figured out how to clean the hydraulic filter yet.
Tractor runs strong and no leaks.
3 of 4 original Bridgestone tires still holding air despite looking horrible.
The service manual in files has been very helpful along with a member Arto who has owned the same model since 1997.
Sadly I failed to take a before picture but the grill was crunched and a couple dents in the hood. I removed the grill and used a piece of 1/2” plywood to straighten out the fins. I’m quite proud of how it came out. I also hit the dents from the inside with a rubber mallet and they are much better too.
/ Ford 1310 4x4 #2
Congrats on the tractor. I've owned its smaller brother (1210) without a loader since around 1991. It was our only tractor for the first 10 or 11 years till our first Kubota. Moved up in size with Kubota a couple times but still have the Ford. Can't bring myself to part with it. It acts much larger than its specs.
/ Ford 1310 4x4
I definitely know the feeling of being emotionally attached to old tractors. I need to move some of mine on but struggle to let go. Need to see a tractor therapist.
/ Ford 1310 4x4 #4
Paper type filters just replace them as you try to clean them
they can 'disintegrate and really cause some problems so its a lot cheaper to replace them
willy
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
2022 WACKER NEUSON G25 TOWABLE GENERATOR (A63276)
2022 WACKER NEUSON...
2011 Ford Explorer 4X4 SUV (A64557)
2011 Ford Explorer...
2019 MULTIQUIP TOWABLE GENERATOR (A63276)
2019 MULTIQUIP...
2020 Freightliner M2 106 Johnston VT652 Sweeper Truck (A64556)
2020 Freightliner...
