Ford 1300 no charge
/ Ford 1300 no charge #1
arcticcat103
Ford 1300
Hello all. I’ve got a ford 1300 tractor 2wd with turf tires I use around the property. For some reason the charging system has failed. I have replaced the alternator and the voltage regulator and still no charge. I have also checked the wires between the alternator and the voltage regulator for continuity (checked out fine). This has me baffled and not sure where to check for the problem. Does anybody have any experience with this issue? Thank you in advance!
/ Ford 1300 no charge #2
Clean all wires you can have dirty connections
and you will never get a charge
willy
/ Ford 1300 no charge #3
Did you get it charging? I recall that there is a fuse for the charging circuit located under a 2 screw plate on the dash. Sometimes the fuses get moisture and corrode
/ Ford 1300 no charge #4
Where you able to charge the battery externally by a charger? is battery okay? what voltage output do you get while the tractor is on?
