Ford 1220 MFWD Hydro switching to turf tires and front wheels hit the spindle
   / Ford 1220 MFWD Hydro switching to turf tires and front wheels hit the spindle #1
AZFord1220
Cave Creek AZ
Ford 1220
After looking for literally years to find them I finally got a set of turf tires to fit my tractor. The tire sizes are correct front being 20x8.00-10 front and 29x12 -15 rear. The rears fit perfectly and the front bolted right up but would not turn. It turned out the inside of the rim was hitting the top of two bolts in the spindle. To clear, the wheels would need more offset towards the outside. My question is this: Did the 2WD version use a different offset than the MFWD? I am puzzled as to what I have. It looks like I will need wheel spacers or a new set of front wheels. Any one have other ideas?
I will also soon have a set of AG wheels and tires plus rear wheel weights.. The rear are foam filled and very heavy one side has extensive sidewall delamination but still some how works the other side is okay but both should be considered junk. The front tire have very few hours on them. Where I live in the desert our "lawns" are covered in 1/4" minus granite gravel. The AG tires tore this up.
   / Ford 1220 MFWD Hydro switching to turf tires and front wheels hit the spindle #2
Any possibility of turning the rims around? That should put more of an offset away from the spindle. Some rims cannot be reversed though.... spacers would then be more appropriate.
   / Ford 1220 MFWD Hydro switching to turf tires and front wheels hit the spindle #3
The 2WD and 4WD shoud not be compatible as the wheel patterns were always different. As LS said, possibly turn around? You could space them out with some thick washers as long as the pilot center is still in the wheel.
The valve stem interferes when I try to flip the wheel. I have ordered some 6 on 120mm spacers that are 1 1/4" thick. My plan is to see if I can get them on a lathe and turn both the inner and outer faces to stay hub centric if possible. I am pretty sure these wheels were used on a different application.
This is what is stamped on the wheel
From the backside of the mounting area to the edge of the tire mounting flange is 3 5/8" It looks like it would need to be no more than 3" to clear. If anyone has this wheel Correct front wheel on 1210 or 1220 MFWD) I would like to verify the correct specification.
Ouch, $237 per wheel. Hello salvage yards.
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
2018 John Deere TX Gator (A50123)
2018 John Deere TX...
7'x20' Homemade Trailer (A50123)
7'x20' Homemade...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
