Ford 1220 HST gear meshing noise when shutting down, any gears turning at idle? Metal in HST filter.
   / Ford 1220 HST gear meshing noise when shutting down, any gears turning at idle? Metal in HST filter. #1
gondiggn
Central Pennsylvania
John Deere 310 Backhoe/Loader
I have my tractor split for repairs. It has 1500hrs. Replaced bad clutch, center shaft in clutch disk was loose and springs were
rattling around. TO bearing was near perfect, replacing anyway. That explains some weird noises while engaging/disengaging clutch.
I hear faint gearbox noise sometimes while running and sometimes it is louder. A couple times I heard tight gear meshing as it was
shutting down. Are any gears meshing in the transmission at idle? It does creep forward a tiny bit when foot off pedal. I have the
hydro unit out but didn't open it yet, maybe today. I may pull the top covers off the transmission today too. I have a small amount of
fine gritty metal in HST filter and very fine metal in hydraulic filter. I have no issues with hydraulics or normal operation, no leaks or
anything, just noise and metal in filters, no issues or weird noises from engine. Does the HST filter only filter the hydro unit oil or
or all the gearbox oil too? Also, I was surprised to not see a pilot bearing even though clutch kits online include one. I think mine is a 95'.
   / Ford 1220 HST gear meshing noise when shutting down, any gears turning at idle? Metal in HST filter. #2
Grindings in the filters is usually indicative of it's eating itself, internally.
ALL ITEMS NOT PICKED UP IN 30 DAYS WILL BE RESOLD FOR STORAGE!! (A50774)
ALL ITEMS NOT...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
TOOLBOX (A50854)
TOOLBOX (A50854)
2014 RAM 5500 FLATBED TRUCK (A51222)
2014 RAM 5500...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
