Ford 1220 HST gear meshing noise when shutting down, any gears turning at idle? Metal in HST filter.
   / Ford 1220 HST gear meshing noise when shutting down, any gears turning at idle? Metal in HST filter. #1
gondiggn
Central Pennsylvania
John Deere 310 Backhoe/Loader
I have my tractor split for repairs. It has 1500hrs. Replaced bad clutch, center shaft in clutch disk was loose and springs were
rattling around. TO bearing was near perfect, replacing anyway. That explains some weird noises while engaging/disengaging clutch.
I hear faint gearbox noise sometimes while running and sometimes it is louder. A couple times I heard tight gear meshing as it was
shutting down. Are any gears meshing in the transmission at idle? It does creep forward a tiny bit when foot off pedal. I have the
hydro unit out but didn't open it yet, maybe today. I may pull the top covers off the transmission today too. I have a small amount of
fine gritty metal in HST filter and very fine metal in hydraulic filter. I have no issues with hydraulics or normal operation, no leaks or
anything, just noise and metal in filters, no issues or weird noises from engine. Does the HST filter only filter the hydro unit oil or
or all the gearbox oil too? Also, I was surprised to not see a pilot bearing even though clutch kits online include one. I think mine is a 95'.
   / Ford 1220 HST gear meshing noise when shutting down, any gears turning at idle? Metal in HST filter. #2
Grindings in the filters is usually indicative of it's eating itself, internally.
LOT LOCATIONS (A51219)
TAKEUCHI TL150 SKID STEER (A51242)
TAKEUCHI TL150...
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
Generac 15KW Generator (A50860)
Generac 15KW...
2021 23ft Cypress Cay Seabreeze 232 Pontoon Boat with 23ft Single Axle Trailer (A48082)
2021 23ft Cypress...
