Ford 1210 muffler
   / Ford 1210 muffler #1
tree grower
Cuttingsville, VT
Ford 1210, Bobcat 742B, John Deere 1050
The original muffler on my 1210 became clogged at about 1000 hours (about 1500 hours ago). A correct replacement cost several hundred $$ at the time, and it appears that today they are not even listed. I have since used a generic replacement which is just a straight pipe with some insulation around it. The original unit was very, very quiet and the replacement is little better than no muffler at all. I really dislike the loud sound of this little engine, and am inclined to build my own muffler. I watched a couple Youtube videos, but those mufflers were still too loud. Any recommendations?
   / Ford 1210 muffler
Was not aware of such a thing. I'll check it out
   / Ford 1210 muffler #4
Generally the larger the internal volume (space) of the muffler the quieter it is
   / Ford 1210 muffler
That's good to know as I work on my custom design.
   / Ford 1210 muffler #6
I would think a much simpler solution is to choose the largest internal volume muffler by dimension with the correct inlet size out of a muffler catalog that will clear your hood/loader/etc.
Not only is there a large number of iterative design features and a substantial amount of science that goes into properly designed mufflers, but you also get it all aluminized or stainless from the factory. I would think a commercial one would likely work better and last longer. Maybe just need to weld/clamp on a flange and tip.
Google "mufflers by dimension" and a number of manufacturers come up. First result for me was Walker and there are lots of designs/sizes/options for example
   / Ford 1210 muffler #7
My Ford 1100 has a 1210 muffler on it, with an adapter that I built to go from the different bolt pattern sizes.
I caught the 1100 on a tree and ripped it in the middle, and found a 1210 in a tractor salvage yard that "looked the same" so I bought it. Turned out that the pipe size was different as well as the flange that bolts it to the exhaust pipe. So I built an adapter and installed it. It has been on their for over 10 years.
David from jax
   / Ford 1210 muffler #8
How about this? I know it’s vertical, but it is something to work with:
   / Ford 1210 muffler #9
It clogged up 1500 hours ago? The math don't work out on that.
New Leader MultApplier L4000G4 (A53316)
New Leader...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
Bull Horns (A53316)
Bull Horns (A53316)
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A55302)
Ditch Witch 6510A...
