Ford 1210 hydrualic filter
   / Ford 1210 hydrualic filter #1
double hunter
Ford 1715
New to me Ford 1210, I want to change the hydraulic filter and fluid, does it have a hydraulic filter or just a washable screen filter or both, it has a hydrostatic trans, seem a little slow in high range, don't know the maint. history, any help appreciated.
Where is the screen filter located and does any one know the number for the spin on filter other than going to the Ford place
   / Ford 1210 hydrualic filter #4
Any CarQuest or Napa will cross the number over.
   / Ford 1210 hydrualic filter #5
On the 1700 the screen is on the right side of tractor between trannie and rear axle. Just trace suction line of hydraulic pump. Also good time to clean out the sump while you have screen out.
   / Ford 1210 hydrualic filter #6
I recently acquired a 1984 Ford 1210
with standard transmission and 740 hr on it and FEL. Right away i changed the engine oil, filter, and air filter, now for the the hydraulic filter, i am having a very hard time locating a replacement, in 1986 i believe Ford introduced a spin on filter to thie 1210 unfortunately mine is a 1984 and only has the small filter behind the screen in the filter housing above the hydro pump. I did not drain the hydro oil yet to see and take measurements on this filter, however if anybody here know where i could find such filter let me know, your replies are much appreciated. mentioned
LOT OF TIN (A58374)
LOT OF TIN (A58374)
2017 Freightliner M2 106 24ft Box Truck (A56858)
2017 Freightliner...
30KW GENERATOR (A58214)
30KW GENERATOR...
2002 Toyota Rav4 SUV (A56859)
2002 Toyota Rav4...
2005 Chevrolet Silverado Pickup Truck, VIN # 1GCHK232X5F955091 (A57453)
2005 Chevrolet...
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
