Ford 1210 Hydraulic pump seal
   / Ford 1210 Hydraulic pump seal #1
adx456
Ford 1210
I have a 1986 Ford 1210 with around 950 hours. Earlier this spring while the tractor was idling engine started pumping out of the breather tube. Long story short, found the seal on the output shaft of the hydraulic pump that mounts to the engine went bad. Replaced the seal put everything back together, used it for about an hour moving mulch around. While idling again the same thing happened, the seal had moved forward. Took the pump apart to inspect it and could not find anything. Reassembled everything and the same thing has happened third a time. Could the pump be going bad or could something cause the system to over pressure and blow the seal out? I am going to test the PSI once I have it back together again. Any input would be greatly appreciated. I have gone through the manual but don’t have a real answer that would cause it.
   / Ford 1210 Hydraulic pump seal #2
I have a recently acquired 1210, but have no idea what could be causing your problem!
Does yours have a belly mower on it? Where are you located?
David from jax
   / Ford 1210 Hydraulic pump seal #3
If the seal is getting pushed out then you have too much wear in the pump housing, gear set and wear (thrust) plate. Time for new internal worn parts or a new pump (which is cheaper most times)
Grove 4x4 Rough Terrain Hydraulic Crane (A49346)
Grove 4x4 Rough...
2014 Ford F-150 Crew Cab Pickup Truck (A48081)
2014 Ford F-150...
Kivel Mini Pallet fork Attachment (A49251)
Kivel Mini Pallet...
John Deere Corn Head (A49251)
John Deere Corn...
Corn Conveyor (A49251)
84in Bucket (A49251)
