Ford 1100 front drive axel parts wanted
   / Ford 1100 front drive axel parts wanted #1
scrumhorse
I am trying to locate part # SBA326370190 pinion gear for the front drive axel on Ford 1100. the gear is no longer available from the dealer. Does any one know where I can locate a new or used one?
Thanks I will give them a try.
   / Ford 1100 front drive axel parts wanted #4
Ring and pinions are sold in mached sets. Even if you find a used pinion it won't match your ring gear perfectly and wont last. I looked on Messicks site and they listed a different part # than you have. You may want to doubble check your part #.
   / Ford 1100 front drive axel parts wanted #5
The New Holland web site has the parts drawings for our 1100 tractors. Here's what they show:
21 1 SBA322050170 PINION, DRIVE Pinion & Ring, Gear, 6 Pinion Teeth, 34 Ring Gear Teeth, Start Year: 01/01/1979
If you haven't tried their site, go to www.newholland.com, then select "North America" under the "Agricultural Business Area", then click the "parts and service" choice, then "search for parts", then use "1100" as the search choice, the 1100 tractor is there first (along with several other items that had 1100 in their name) then drill down through the selections.
Thanks for the information I was able to get my gear from the company in Kentucky. My 1100 will be up and running shortly.
   / Ford 1100 front drive axel parts wanted #7
Make sure when you install the new ring &pinion to set the preload on the pinion and the backlash on the ring gear.
   / Ford 1100 front drive axel parts wanted #8
For sure. I let a friend use my Ford 2120 once and he blew the front ring and pinion. A dealer (not mine) replaed the ring and pinion for $1600 and didn't set it right. It blew in a week. The one that replaced that is still going strong 10 years later.
Andy
   / Ford 1100 front drive axel parts wanted #9
I'm also looking for a PINION, DRIVE Pinion & Ring, Gear, 6 Pinion Teeth, 34 Ring Gear Teeth, Start Year: 01/01/1979 for my Ford 1100 4 x 4. If you have one please send me a reply. Thxs.
2023 CATERPILLAR 279D3 SKID STEER (A51246)
2023 CATERPILLAR...
2015 FREIGHTLINER CASCADIA DAYCAB (A52472)
2015 FREIGHTLINER...
2- 30 X 42 TRIANGLE PIPE RACK (A52472)
2- 30 X 42...
JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
JCB 525-60T4...
2016 CHEVROLET SILVERADO 3500 DUALLY (A52472)
2016 CHEVROLET...
2019 KENWORTH T880 (A52472)
2019 KENWORTH T880...
