ford 1000 series will not steer well
   / ford 1000 series will not steer well #1
lralph
newburgh indiana
ford 1000
Wonder if positraction is stuck. What to do?
   / ford 1000 series will not steer well #2
easy to check! jack up both rears, with tractor off and trans in gear, spin a rear.. what does the other do?
Thank, soundguy
Jacked it up in gear and both wheels respond in tandem to moving one. What is the solution to problem? How to fix? Is it a dealership fix? What next?
   / ford 1000 series will not steer well #4
i'd be looking at the diffy lok...
   / ford 1000 series will not steer well #5
Have you tried pulling up on diff lever
   / ford 1000 series will not steer well #6
anything?
WEATHER GUARD SIDE BOX (A50854)
WEATHER GUARD SIDE...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
Agway Bale Accumulator (A50515)
Agway Bale...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2009 International 7400 Chassis Truck, VIN # 1HTWGAAR89J160632 (A51572)
2009 International...
